Hello!
Make a long story short, I have used iTunes for like 20 years and finally finally wanna migrate. Heard nothing but good things from musicbee.
I have played the portable installation on my (local) NAS drive where I also have my iTunes library.
But:
When I start the program and get to the initial installation, it asks me this: check "import tracks and artwork from iTunes" but also there is the option to select a directory manually. Do I check BOTH or just the iTunes one? I want to have everything mirrored/imported from iTunes as much as possible, Covers, ratings, playcounts etc.
Another thing that makes me wonder if I am doing everything right: It scans for the files...around 31 000 I got. Initially, it gets to like 9000 pretty fast but ever since then, it is just like 5 files every 10 seconds or so... this is gonna take ages. Is this really correct? Why is it taking that long? The files are on a locally connected drive that is pretty fast.
Also, ultimately I wanna move the files to a new Music Bee folder from the iTunes one (but on the same drive), but I heard you can move those later on?
Anyway, I am just not sure if this initial setup is going well. I want to migrate but I am careful with my library I have care for for 20 years, I don't want anything to get messed up in this initial step!!
Thanks for the help.
