Author Topic: Twones  (Read 4857 times)
Chaddywicker
Just discovered MusicBee and I've become a fan.  Thanks for your hard work!
At some point in the future, it would be nice to see "scrobbling" support for Twones added.
http://www.twones.com/
http://www.twones.com/pages/api
http://www.twones.com/pages/developers
Thanks again!   :)
Last Edit: November 10, 2009, 09:47:22 PM by Chaddywicker
had a quick look and they are still in private beta but will be shortly opening this up. So let me check again next week but if they make the api easy to scrobble with then no problem to include
Chaddywicker
Just wanted to follow up.  Twones made some changes.  I don't know if this makes it easier to integrate Twones, but wanted to mention it if you hadn't noticed.
Btw, the amount of work you seem to be putting into this is incredible.   :D
thanks for letting me know - i checked their website for several weeks after you suggested and every time it kept saying the were starting up shortly, so in the end i gave up on them.
I'll check it out again over the next few weeks to see what i can do.
Chaddywicker
