Any way/chance of locking the volume control?Could it be done as a plugin?
do you think it could start at a value definite by the user and changed but the users just moving the volume slider?for example, start musicbee with volume always set at 30% and increase moving only the sliders?
Quote from: gaiastar on June 30, 2024, 04:11:30 PMdo you think it could start at a value definite by the user and changed but the users just moving the volume slider?for example, start musicbee with volume always set at 30% and increase moving only the sliders?Hi gaiastar. I'm not sure l understand.The idea behind the plugin was to disable the volume slider when ever the plugin was enabled.Leaving the slider active would defeat the purpose of locking the volume, I think.
I would like to ask you if could possibile to setup to start musicbee always at 30% volume , in short a low value, or a custom value
Quote from: gaiastar on July 01, 2024, 05:48:43 PMI would like to ask you if could possibile to setup to start musicbee always at 30% volume , in short a low value, or a custom valueI may still be misunderstanding, so bear with me:In the preferences (refer to my screenshot above), you are able to manually type in the volume percentage in order to permanently lock it at that level.Is that not what you require?
Ah, I see what uu mean now.I can add a checkbox in the preferences with something like "startup only" where if ticked, would only set that volume at startup only.I'll probably do that the coming weekend if I make the time.
The above request has now been implemented - get the update on the same download link.
Can you share a screenshot of your preferences like my screenshot above?And just to rule off a mis-match in the way I've handled the plugin database on this update:Can you go to ...\appData\mb_volumeLock\... and delete the files in there, then restart MusicBee.
Initial volume @ 0,5058824Initial startup @ TrueShutting down: MusicBeeClosing
Locked @ 0,5058824Startup only @ True
