Author Topic: Volume Lock  (Read 6713 times)
gaiastar
Thanks slonopot - that's certainly good advice right there!
Using two data types interchangeably is just delaying the inevitable complications down the line.
#3 is definitely a must, regardless of how small the code is. I shall heed your advice.
Regarding the attached screenshot, what monitor size or dpi scale are you using there?
I will admit that I winged most of the control positioning and didn't necessary use anchor points. I recall it being a headache the last time I worked on a panel plugin.
hI
may I know where could the plugin updated and fixed?
thanks
hI
thanks
Between this plugin and the several issues/requests Mayibongwe is working on in LyricsReloaded, I wouldn't try to rush the poor guy, when they get fixed they get fixed.
gaiastar
@gaiastar:  does this newly posted alternative plugin help you at all?
https://getmusicbee.com/addons/plugins/511/link-system-amp-musicbee-volume/
hi sveakul
I wanted to reply to the the topic original but it's pretty old
i would like an option to start musicbee with a volume at 20% or 15% ,in short a custom volume setting/value
I think i will wait ,since i guess the author is busy
about the plugin , it doesn't fit for me
A plug-in that simply links the volume level of MusicBee and Windows Volume Together.
   If you change MusicBee Volume, The System Volume will change also and vice versa.
thanks
  • Heal The World
But in the meantime, just go to the settings file in the appData folder and manually change the volume to 0.5.
On restart, that should set Musicbee at 50% volume.
Gaiastar, btw, did you ever attempt to manually override the volume on the plugin's appData folder?
Strength and Honour (2025)
