Author Topic: edit tags error  (Read 583 times)
Dizza17
Hi There,
Not sure if this is related but this error consistently pops up when i go to edit - select all. using the latest version of 3.6.
 MusicBee v3.6.8919.33431P  (Win10.0), 6 Jun 2024 15:10:
   at #=zUGP$bCFvyvRsiBTfBnbVWPQ=.#=zA$AxBpX4lHw5(#=zUGP$bCFvyvRsiBTfBnbVWPQ= #=z5xqfnXk=, HashSet`1 #=zR228glyx9CJL_hZIMw==)
   at #=z3755qAHgfbSyal_nVmuCMc4=.#=zYC3NlozwLz32(IList`1 #=zJCw9BBg=, Boolean #=ziElHeos=)
   at #=z3755qAHgfbSyal_nVmuCMc4=.#=zvkiDKhs=(IList`1 #=zJCw9BBg=, Boolean #=z6orvMGU=, Boolean #=ziElHeos=)
   at #=zYdI5i8kMzDGj8sVmbUvsI4qgo5S$.#=zFu_F1jyJf5MZ3Wnhuw==.#=zXQpKOumEzmN0(List`1 #=zIHdrHm_lpO9Y)
   at #=zYdI5i8kMzDGj8sVmbUvsI4qgo5S$.#=zYfhZaT2mFpfYWERlrA==()
   at #=zYdI5i8kMzDGj8sVmbUvsI4qgo5S$.#=zI1NS_d2mUSL0(#=zF_J3roLOD4L1BYusuui59Tk= #=zyidvIDQ=, Boolean #=zfKLu$3vYTpyn)
   at #=zYdI5i8kMzDGj8sVmbUvsI4qgo5S$.#=zasT8XIJACHTD.#=zT5L3XK1NBuda(#=zjFuEFQj4LQgCy9127mEJZGvekZwe #=z98aFLLs=)
   at #=ziwzPJswjThhCAMVJuuV839c=.#=ziBbAZgREJqyd(Boolean #=zkAb1DF0=)
   at #=zYdI5i8kMzDGj8sVmbUvsI4qgo5S$.#=zjrPtnpuEJ3q7()
   at #=zYdI5i8kMzDGj8sVmbUvsI4qgo5S$.#=zqFVg9SI=(ApplicationCommand #=zrk9GHYU=, Object #=z9BfLJ2U=, #=znIELsd480H4tEJzG7e82E_8= #=zJCw9BBg=)
   at #=zniBT16xsnZT2cLGjDXGWVGo$U3Ni.#=zrYAdoJE=.#=zKBpf9Ic=(ApplicationCommand #=zrk9GHYU=, Object #=z9BfLJ2U=, IList`1 #=zJCw9BBg=)
   at #=zTu5uRCoIwqm3Zw_XNX1fynQ=.OnClick(EventArgs #=z98aFLLs=)
When the rich wage war, it’s the poor who suffer.
can you post a screenshot showing the panel you are selecting files from
Dizza17
Hi Steven,
See attached as requested. https://imgur.com/a/8cEQyxf
  • Heal The World
Couldn't reproduce it myself using the panels on your screenshot.
Does the error also occur if you use your hotkey instead <CTRL + A> as it links to the same function?
I would advise that you send Steven a PM with your settings file in the meantime.
I'm going to embed your screenshot here for ease of reference:
Strength and Honour (2025)
