Author Topic: Consult database remotely  (Read 230 times)
samsonwilliams
Hi Everybody: Is there a way to check my musicbee database online? Uploading it to a wordpress or site? I have a lot of information on musicbee that I would like to consult remotely?
Hi.
You won't be able to do anything like this directly.
The MusicBee database file is a proprietary format that - short of reverse engineering it - can't be accessed or read by other programs.
Depending on what information you want to access and why, you might be able to come up with a different process that can export the same data to an accessible format - say a .csv file - and then read from that.
If that sounds feasible, check out the Additional Tagging and Reporting Tools plug-in:
https://getmusicbee.com/forum/index.php?topic=3833.0
