Author Topic: having a button to find all the same track title  (Read 575 times)
monkey
i often search for different versions of a track
i found the option above which runs very well
however i wonder if it could be possible to create a button in the toolbar to do it more easily ?
or is there any possibility to use hotkey ?
monkey
it's also possible to use auto-playlist (using the left panel in auto-hide mode) which is a better solution than using Menu...
this solution is as easy as a button to use, so it's good for me...
You can instantly search by any of those fields (and any others) by using a middle mouse click in the main panel. The value you click on will be the search parameter.
monkey
Amazing, it runs !!! MB has so much options...
I have no mouse actually but it's also possible after configuring the touchpad !
thanks
