Author Topic: Savanna & Wisteria (light skins)  (Read 5453 times)
karbock
Two light skins based on Cheetah DNA 1.4 by hiccup.
  • Savanna: light warm tones based on a brown palette.
  • Wisteria: light tones based on a mauve/violet palette.
They are in .XML format (editable), so that you can adapt them to your liking.
Download links
Screenshots
Description
Savanna skin
Wisteria skin
Album view
Album & Tracks view
Now Playing
Preferences
Changes, compared to Cheetah DNA
Gradients used for:
  • player panel background
  • column headers
  • highlighted tab
  • scrollbar buttons
  • setting buttons
Alternating colours added for:
  • now playing
  • thumbnail browser
Fonts used in the screenshots
Location
Font name
Supported scripts
Default fontUbuntuLatin, Greek, Cyrillic
Sub-grouping headerLiterataLatin, Greek, Cyrillic
Now playing trackLiterataLatin, Greek, Cyrillic
LyricsMonomakh UnicodeLatin, Cyrillic, early Cyrillic (for Slavonic)
Last Edit: July 16, 2024, 06:40:07 PM by karbock
  • Heal The World
Haven't gotten around to trying these out just yet, but the screenshots look awesome.
Thanks for sharing karbock.
The direct G Drive link above will make your dashboard stats come up short in the future.
Are download counts not something you'll want to look back on down the line?
Strength and Honour (2025)
karbock
Thanks for your kind comments! Once you've tried them out, don't hesitate to send your feedback.
And as for the download counts, it's a wise remark.
  • Heal The World
Just downloaded these. I like Wisteria the most. Simple and elegant.
And of course, a 10/10 on the presentation (just like any of your other topics).
I love the sig too:
Nice. Very suave.
Thanks for sharing these skins karbock.
karbock
karbock
Savanna & Wisteria v2.6.5 uploaded:
* Warmer hues for Savanna
* fine-tweaking of some colours
The screenshots in the first post are up-to-date.
musicbox7752
can you tell me what the flags show - the language or the country? and how exactly to do the same on another regular standard theme? for example, my language tags are filled out - do I need to put pictures of flags somewhere?
karbock
The flags in the picture represent the language, displayed via the "Highlight" tag, whose content is defined in the highlighting rules (see Preferences > Tags(2) > highlighting: [Define Rules...]).
In this case, the list of highlighting rules depends on the number of languages present in your collection: one rule per language, since there is automatic attribution (unlike in the Thumbnail Browser).
For the "Highlight" tag, the icons must be put in:
  • PORTABLE version:
    (MusicBee Application Path)\Icons
  • INSTALLED version:
    %APPDATA%\MusicBee\Icons
Note that if you select "Language" in the Thumbnail browser, MusicBee will automatically display the matching flag, provided it is present with the same name (eg. "English" -> "English.PNG") in:
  • PORTABLE version:
    (MusicBee Application Path)\Library\Artwork\Grouping Icons
    %USERPROFILE%\Music\MusicBee\Artwork\Grouping Icons
The "Highlight" tag is designed for 16x16 icons, and a maximum width of 48 pixels (for the latter, unless you manually fiddle in MusicBee3Settings.ini). In my setup, I use 20x20 icons, since 16x16 flags are not easy to recognise in my screen resolution (1920x1080, 100%).
Below, some examples of rules:
name
rule
icon
color
text
LNG=multilingualmatch all of the following rules:
Language - is - multilingual
(multilingual).ico(not specified)(not ticked)
LNG=Englishmatch all of the following rules:
Language - is - English
Language - is not - multilingual
United Kingdom.ico(not specified)(not ticked)
LNG=Frenchmatch all of the following rules:
Language - is - French
France.ico(not specified)(not ticked)
Important notes:
  • When you want to select the icon, MusicBee lists .PNG pictures only, although it also accepts .ICO files. The difference between the two types is that .PNG files are often stretched, whereas .ICO files are displayed without stretching ("pixel perfect").
  • To list the .ICO files in the file selector, enter "*.ico" as filename -> [Enter].
  • (This could provide matter for a Wishlist entry.)
If you don't have flag icons, some possible sources:
Last Edit: February 05, 2025, 09:51:07 PM by karbock
musicbox7752
Thank you. figured it out. it turned out. now I'm going to think about how best to organize everything. and what have you done with the "plus", "minus" and "bell"? It's a pity that the limit is 3 icons in total
By the way, I took the flags from here, but I had to convert them to PNG.
karbock
Thanks for the link to the kapowaz collection!
In my "Highlight" tag, the three positions always have the same meaning:
1. instrumental / sung / sung a cappella / spoken
2. language
3. has lyrics?
The special icons are from the fugue icon pack, designed by Yusuke Kamiyamane:
https://p.yusukekamiyamane.com
Icon attributions:
  • instrumental: bell.png
  • sung a cappella: minus-circle.png
  • sung with accompaniment: plus-circle.png
  • spoken: balloon.png
  • multilingual: color.png
  • invented language: light-bulb.png
  • unknown language: question.png
  • lyrics (unsynched): document-text.png
  • lyrics (synched): blue-document-text.png
N.B.:
- "multilingual" is stored in the "Language flag"
- "Instrumental", "Sung", "Spoken", "A cappella": stored in the "Genre" tag, which I used as a keyword list (I don't use the "Keywords" tag).
For example, this is what Genre contains:
- for a cantata by Bach: "Sung; Classical; Baroque; Religious; Cantata"
- for a piano concerto by Beethoven: "Instrumental; Classical; Classicism; Orchestra; Concerto; Piano"
EDIT: added "question.png"
Last Edit: February 07, 2025, 09:42:54 AM by karbock
