Author Topic: System.FormatException: Value is not properly formatted.  (Read 411 times)
Ken_MB
Open musicbee and popup:
MusicBee v3.6.8906.38935D  (Win10.0), 22 5月 2024 23:01:
   在 MusicBeePlugin.FontSerializationHelper.Deserialize(String value)
   在 MusicBeePlugin.LyricsRenderer.UpdateFromSettings(SettingsObj settings, Int32 width)
   在 MusicBeePlugin.FrmLyrics.UpdateFromSettings(SettingsObj settings)
   在 MusicBeePlugin.FrmLyrics.FrmLyrics_Load(Object sender, EventArgs e)
   在 System.Windows.Forms.Form.OnLoad(EventArgs e)
   在 System.Windows.Forms.Form.OnCreateControl()
   在 System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   在 System.Windows.Forms.Control.CreateControl()
   在 System.Windows.Forms.Control.WmShowWindow(Message& m)
   在 System.Windows.Forms.Control.WndProc(Message& m)
   在 System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   在 System.Windows.Forms.ContainerControl.WndProc(Message& m)
   在 System.Windows.Forms.Form.WmShowWindow(Message& m)
   在 System.Windows.Forms.Form.WndProc(Message& m)
   在 System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   在 System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   在 System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
This error is coming from the Lyrics plugin. Please (re)post the bug report on the thread for the plugin so its developer can see it.
Please add the following infornmation:
- What were you doing when the error occurred?
- Does this error occur every time you try to do what you were doing?
- Exact steps to reproduce the issue.
I'm locking this thread.
