Author Topic: musicbee doesn't find "The Beatles" in my network folder  (Read 1219 times)
Helmut Harnisch
MusicBee V. 3.6.8849 on Windows 11
I start with a new library by holding shift and start the program. I choose New - folder - networkfolder. My music is stored on \\DMP_SAMBA\Share\FFEF-F1E7\Musik-SSD. As you can see in the screenshots, there is a folder "The Beatles" between "The Beach Boys" and "The Bee Gees". When i unfold the network folder in the setup in musicbee, the folder "The Beatles" is not shown. Is this a bug or is something hidden by default?
with Beatles
Last Edit: May 17, 2024, 09:37:11 AM by Helmut Harnisch
In MB have you looked under "T" for The Beatles?
Do the other groups beginning with "The" appear properly?
MotleyG
Perhaps your network folder has two sub folder, "Beatles" and "The Beatles". If "The Beatles" is empty or at least has no music files in it, then it won't get listed in MB. Check if your files are all stored in a "Beatles" folder instead.
Helmut Harnisch
All other Artist appear under "The ..." when tagged as "The ..." Definitely on my SSD all files under "The Beatles" are tagged for album-artists and artist as "The Beatles". See screenshot when added into musicbee. Obviously musicbee doesn't scan this folder. my songs are sorted as "Album Artist\Album\Songs".
Is there a limitation of folders? I have 49826 files, 3855 albums and 1321 artists on my SSD.
# New Screenshots added #
Helmut Harnisch
No, all is under "The Beatles" and the files all are tagged in album-artist and artist as "The Beatles". It looks like the import section of mb dont show or find the folder "The Beatles".
  • Heal The World
So a global search (Ctrl + F) across your whole library does not turn up any song from 'The Beatles' folder?
I'm guessing there's some active <sort tag> affecting just that particular artist (assuming the library has the songs in question, but just under a different section).
When you compare the artist folder count in your windows explorer vs what MusicBee shows, is it just this one Beatles folder that is missing?
Strength and Honour (2025)
Helmut Harnisch
No, it does only find songs contained in album samplers. I search the whole library and no filters assigned.
When I add the folder "The Beatles" by hand via files - add files, all albums are added, are to be seen in the library and find all songs.
When i say find new files in my folder, a window comes up and asks, if i would delete the albums and songs not found in my streamer ssd.
Its that strange, that with adding files the folder named "The Beatles" is unseen...
This is a very strange problem. I did notice in your screenshot that the "The Beatles" folder in windows explorer is set to a future date "15.06.2024" so perhaps somehow it is corrupted in some way that MB cant read it
Helmut Harnisch
Thank you, didn see this. I changed the date to 16.05.2024 including subdirectories and checked the permissions. Deleted the MB library and created a new one with different name. Same as before: the folder "The Beatles" will not be searched or included.
If I add the Beatles subfolder by hand, all is fine, the album artist "The Beatles" is shown and sorted between "The Beach Boys" and "The Bee Gees". Very strange!
Last Edit: May 18, 2024, 11:03:18 AM by Helmut Harnisch
MotleyG
Have you tried renaming this folder and rescanning again? Try something notably different like "Test Beatle" and see if MB picks it up off the next scan.
EDIT: Change it back to "The Beatles" afterward and see if it becomes available again in MB.
Last Edit: May 18, 2024, 03:56:57 PM by MotleyG
Helmut Harnisch
It makes no difference, the folder is not be seen and also not imported. Very strange!
MotleyG
MB cannot arbitrarily decide to exclude a file or folder. I would suspect some kind of corruption has occurred, especially given that strange future date that was there originally. Check your system clock. Scan the disk. Maybe even check the file integrity for that folder. Something external is influencing this.
Helmut Harnisch
After deleting ..AppData\local\musicbee\InternalCache and over-installing musicbee, all is fine. All expected folders are to be seen before I read it in the database.
So its dependent on the internal cache that hasnt updated. Thank you all for your help and patience.
Helmut
