Author Topic: Bug When Syncing Playlists Containing ASX Files  (Read 851 times)
tjinc
Only spotted this when testing sync to a new phone. This relates to syncing a playlist that contains one or more ASX files.
The correct audio file (e.g. the FLAC file that the ASX file links to) is always copied across as expected but the playlist file is not always updated and can remain with a reference to the ASX file. This seems to be linked to the 'on-the-fly conversion' setting:
  No on-the-fly conversion:
  Playlist file on device retains reference to ASX file.
  Options 'convert to MP3' and 'only convert files not already formatted as MP3':
  Playlist file on device correctly updated with reference to MP3 file.
  Options 'convert to MP3' and 'only convert files with a lossless format':
  Options 'convert to MP3' and 'convert all files':
Tested on MusicBee ver 3.6.8878 P
Initially noticed when syncing to phone but testing done using local folder configured as virtual device.
tjinc
Looks good now, thanks.
Last Edit: April 29, 2024, 11:22:30 AM by tjinc
