Author Topic: Lyric plugin putting in ads / ticket / concert info  (Read 667 times)
gnomeusic
Some lyrics i've notice listing for ticket sales and stuff like that in the middle of the lyric
Heres and example i highlighted in purple or tried to.
Russ - I'm Tired
See here.
Either you or Dzib should post this in the appropriate topic, which is the Lyrics Reloaded topic.
(regrettably neither you nor Dzib make a mention of using that specific plugin, so this will have to be an educated guess on my part)
gnomeusic
Yes its lyric reloaded plugin, thanks. Trying to do the same as Dzib
See.*(?=LiveGet).*(?=\$)\$\d{1,}
with the advance search and replace but honestly no clue how to begin..
I will post in the plugin topic shortly thanks
It is recommendable that both you and Dzib are trying to solve this by yourself, but since this seems to be some new issue, which the plugin may be able to solve in the first place, it would benefit other users too if it could be solved/prevented there.
Last Edit: April 19, 2024, 05:58:45 PM by hiccup
Since you've confirmed that you're using the plugin, please report the issue on the plugin's thread. Follow the link hiccup included in his first reply.
I'm locking this thread.
