Find them in the Computer node folder structure, right click them and see if the Send To menu shows they're in one of the other sections (Audiobooks, Podcasts). You can put them back in the music library from there.
Alternately, if they're in a bunch of different folders and it's cumbersome to do it that way, you can manually check the other sections for errant files.
