Author Topic: Use MusicBee with keyboard ONLY  (Read 5823 times)
plywood
Now that would be great! 'Cause it's faster than the mouse. Could you pretty please make it happen? :)
Also a hotkey to toggle maximize/minimize the main windows would be superb!
Kudos to the author!
i'm more a mouse person myself - its likely i will not think of the things you have in mind, so could you list the main things keyboard handling is lacking at the moment?
no problem to include a hotkey to maximise/minimise the main window
plywood
I'd like to move between the windows using the TAB key.
I'd like to be able to select everything in the 'Now Playing' window by pressing Ctrl+A.
if you are using the latest beta posted today the tab key should already be tabbing between the panels - are you not finding that to be the case?
plywood
Uh, my version is 1.1.3494. Not the latest, I guess. I shoulda try the new one. Thanks.
done for the latest update in the 1.1 beta topic
