Author Topic: AutoDJ -> Playlist  (Read 476 times)
GotanMusic
Hi
Once I have a list of tracks in AutoDJ is it possible to save that list as a Playlist?
I can't seem to find a way to do this. I thought I might be able to at least select the table and then cut and paste, but although select seems to work, it's only on one row and then can't do anything with it.
Maybe I'm just starting in the wrong place but it does seem possible to do this the other way around i.e. Playlist -> AutoDJ
Many thanks
Chris
The Incredible Boom Boom
There does not seem to be a way to accomplish this, but I question the necessity, since Auto-Playlists function in a highly similar manner?
  • Heal The World
The autoDJ is not something I use, but I would imagine that its track list also gets queued to the upcoming/playing tracks panel like any other list?
Then from thereon, it's a matter of selecting all > right-clicking > adding to playlist.
I agree though that an autoPlaylist would probably be the best tool for the job.
Strength and Honour (2025)
karbock
In the AutoDJ tab, a list made with the "Preview" button cannot be exported directly,
but if you double-click on its first row,
the list will be taken as new Now Playing list, which you can then save to a playlist as Mayibongwe suggested.
