Author Topic: changing the background' color of the buttons  (Read 1373 times)
monkey
is it possible to change  the  background color of the buttons ?
using the Musicbee3.xmlc ?
Last Edit: March 25, 2024, 07:56:57 PM by monkey
The Incredible Boom Boom
Bumping for visibility. I believe the background color of these buttons can be changed, but I'm not sure which element they belong to.
Does that mean that neither of you has found (by searching the forum...), or is familiar with the How to make modifications to a skin that you like topic?
Apparently so.
Nor have they read this:
https://getmusicbee.com/forum/index.php?topic=40804.0
Last Edit: May 06, 2024, 10:56:46 PM by phred
monkey
i'm totally alright with this
thanks for all your answers
but i just would like to add that it's sometimes hard for a newbie to find an information on the forum
for example i searched "id" "list" "elements" "skin" but without result...
about my initial topic, i'm just exploring another solution using icons...
it seems to be better... MB is really amazing !!!
thanks again  :)
Yeah, finding the correct search terms for software that you haven't been using for long can be difficult.
I just modified the MusicBee - custom Google search page so that if you now use it to search for e.g.:
change colour
   or
skin elements
the top entry now shows the 'How to make modifications to a skin that you like.'  topic.
monkey
Congratulations
In my opinion it's better and above all very readable
You've made a big effort to organize your database
It will certainly be easier now to find accurate informations
Simple and effective!
