Author Topic: Tag Sync  (Read 139 times)
irshjet
I am wondering if there is a way to sync tags between DB's?    I have 2 MB DB's setup,  one on my Laptop and one on a external drive which houses all my music.  I have been updating the tags on the LT,  but would like to have these changes sync over to the other DB without having to duplicate the work.
  • Heal The World
Question's a bit confusing due to the interchangeable use of "database".
At one point, database seems to refer to MusicBee's library file and at another, seems to refer to the actual music files.
Tags are generally saved to the music files themselves.
So if you have two sets of the same tracks between the laptop and the external drive, you can't exactly "sync the two without duplicating the work".
If the end goal is having one library shared across different setups, see here:
https://getmusicbee.com/forum/index.php?topic=36915.0
