https://imgur.com/a/pLSQYzhQuestion 1:
I currently have some songs of 1 artist (ex. ASAP Rocky) in my general music folder (D:\Kevin\Music) (Pic 1) and some of those are in an album's folder (Pic 2).
I would like to move all these into a single folder named such (ASAP Rocky), but if they're in a folder already I want to keep them there (i.e. the Album's folder). Using SendTo > Folder(Move) just dumps them all into a single folder with no subfolders (Pic 3). Is there any nice way to do this?
One way I tried is to physically move the files by cutting and pasting (Pic 4) and then use LocateMissingFiles and manually find the files but it only smartly finds the rest of the files if they're in the same subfolder (i.e. only in the album folder, I can't do every file in the overall ASAP Rocky folder) (Pic 5).
Question 2:
if I wanted to change a file's name, i know I can do that in the Edit window and it will change the corresponding file name. Is there any way to do this for whole folders with multiple tracks? (Pic 6) For example I want to change the folder from [A$AP Rocky - LONG LIVE ASAP] to [LONG LIVE ASAP (2013)] or something like that? I know I could change the folder name in Windows Explorer then use LocateMissingFiles and select the folders slowly, but is there any better way?
Question 3:
I can't find any shortcut/hotkey for Send To > Folder (Move) > Move Files to Folder, only Move files to Organized Folder. Is there anything for a folder that I can choose myself?
