Author Topic: reading only tracks checked as favorites  (Read 225 times)
monkey
Hello
is it possible to read only tracks checked as favorites ?
thx for reply
Monk
tjinc
If I understand you correctly, you just want to be using a very basic auto-playlist.
See Wiki entry here.
The single rule you will require depends upon how you are identifying your favourite tracks (for example, if you rate your favourite tracks with 5 stars then the rule will be 'Rating Is 5 Star')
monkey
