Hi!
First of all, thank you for your job with the application.
I have experienced a problem while trying to subscribe to a podcast. MusicBee says "Unable to verify the validity of this URL". I have looked into the RSS file and I think I have the problem (that it is not a problem from MusicBee):
This is the RSS feed:
https://www.rtve.es/api/adapter/programas/172212/audios.rssThere is a line where I see:
<category>/iRTVE/Temáticas/Rock & Roll</category>
Well, the problem is happening because the parser is expecting something after the
& (I guess it should expect &).
The correct tag should be:
I don't know if it is possible and/or if it is a botched job, but maybe the system could try to get the RSS, if its structure is not valid it could try to replace single & with & and try to read it again.
