Author Topic: allow for pasting a complete cuesheet using the Tag Editor  (Read 1212 times)
It is possible to create 'CUESHEET' tag using the tag editor.
Which could be useful to embed a cuesheet in a file.
But when pasting a cuesheet into the value field, it will only except the first line of the cuesheet and everything else is ignored.
Can it be changed so that it accepts the whole cuesheet?
I also noticed that there is a difference between the name of the cuesheet tag of a (flac) file that already contains an embedded cuesheet, and one that you create yourself.
The former has FILECUESHEET, the latter CUESHEET.
Not sure if that's important but I thought to mention it.
this was done a while ago in the tag inspector, except for .mp3 and .m4a files which is supported for the next update
Thanks.
Especially since this is something mostly useful to have for lossy audio.
I was messing around with this today but it didn't seem to work to copy the cue sheet into the tag. I'm new to cue sheets, though, so I may be missing something. Any suggestions?
