Quote from: Leslio7 on September 18, 2016, 10:20:55 AMQuote from: Steven on September 18, 2016, 07:45:24 AMQuote from: Leslio7 on September 17, 2016, 07:55:08 PMIn the previous MusicBee version it worked perfectly. I wonder if I'm the only one with this problem. you are the only person who has reported this so my guess is you have installed and are running the new musicbee version from a different locationI'm running MusicBee from Mozambique, is there something I can do to resolve this issue?location on your computer ie. you have two installed instances of musicbee
