Hi, i started using today MusicBee, i was wondering if i could use ASIO. i navigated myself into the setting and found out that i could. the reason why i switched to MusicBee is that with foobar i wa not able to get consistent DSD playback with ASIO. once got here i setup ASIO in voicemeeter and in musicBee. in musicbee i chose the ASIO option and the Voicemeeter virtual ASIO so that i could controll it within teh mixer. as my A1 output in voicemeeter i chose my Soundcard ASIO driver. by doing so, the only stable resolution i managed to get was of 96khz at 24Bit. i would like to go up to 192 but then the driver crashes.
as a second and most importat issue i encountered was that in order to play DSD files in MuiscBee i had to choose the option to play the DSD files converted to PCM. if i choose the raw DSD i get an error, if i chouse to play them as DOP, i just get white noise from teh track.
ALL DSD FILES ARE .dsf
DAC: Creatve Sound Blaster x3
all drivers and software are up to date
all windows settings reguarding audio are set as they should.
