Hi everyone,
I'm still very new to MusicBee and after importing a bunch of my music, I started going through the built-in skins to try different looks. I also clicked around in the options and panel settings, but not too much. At some point though I did something which screwed up the progress bar, because now it does not actually advance through the time of the song, it just stays at the beginning and the time on the side of the bottom panel section stays at 0:00 as well. I'll add some pics to show what I mean.
How it looks now, with the bar frozen:
(Imgur link)So here the song is playing, you can tell by the little visualizer on the left, and is further in than 0:00 but like I said the time never changes and whenever I try to move the green circle to scrub through the song, it snaps back to the beginning again and restarts the whole song. For context the theme I'm using in that screenshot is Dark Metro - Green.
I was going through some other skins literally a few hours ago and this problem didn't occur, I have screenshots I just happened to take because I thought the designs were fun:
In Bee78, you can see the progress filling up the bar in that gold color.In the Tron Punk theme, the little Recognizer did move.Also, when I try to use the wave bar, the a similar thing happens, it's just a thin flat line that I can't interact with either.
Here are my settings for what it's worth:
Preferences > Layout (1)Panels ConfigurationSometimes all of the options for the bottom panel don't show up in preferences depending on the skin, but this problem persists in all skins I've tried since it started, including ones where I can change stuff about the progress bar and wave bar.
This doesn't majorly affect usability for me but it is just frustrating and visually weird. Please someone let me know where I screwed up here and how to get the progress bar back to normal. Thanks!
