Author Topic: Unexpected order  (Read 360 times)
Gophergawd
Keep getting the following error when trying to downloading the newest Axe of the Blood God episode. I tried unsubscribing and resubscribing.
Thank you!
MusicBee v3.5.8447.35843Store (Win10.0), 25 Feb 2024 10:02:
   at #=zeMqc5$TxqC0C2OYgY3peUzs=.#=zCZD7KEQcWeaY(#=zfRj55iuU2I9aTu7pknkYmpI= #=z7jtehBc=, #=zObu2rEcnuU4$ScKaEEKi22WKogvzYZIwpg== #=zB8RprTI0NpVH)
   at #=zUAgrikuuIGni6ooFSJUqzaKMbuWR.#=z8q5JBD0=.#=zKB7MGvdpygIb(List`1 #=ztTiYibs=, #=zpt7RDMITgV7cf48du2iU1mc= #=zwIpKsfg=)
   at #=zUAgrikuuIGni6ooFSJUqzaKMbuWR.#=z8q5JBD0=.#=zq0AIWf0=(ApplicationCommand #=zL7nS3_E=, Object #=z3B_WUE8=, IList`1 #=ztTiYibs=)
   at #=zL2Bwg2pscCkOEWT7Dsd8gs4=.OnClick(EventArgs #=zmmOoBdU=)
Please provide a link to the podcast you've having issues with.
i found the podcast and can reproduce the error.
Its fixed for the next update but if you want it now you will need to install the desktop or portable version of MB and then replace it with a patch version i can provide.
