If I am understanding correctly - I can do this with the library drive, but I would need to copy everything over to a different drive first, wipe the first drive, then copy everything back to it again and that toggled setting will carry out the embedding task?
No-no. If by "wipe out first drive", you mean the "main 4TB library or portable drive", then no, that's not what we're saying.
Nothing needs to change on your main 4TB drive.
What essentially needs to happen here is for a resync to be done to your 128GB thumb drive so that the enabled embed artwork option does its thing.
There are many ways to trigger the resync. The easiest that we suggest is to:
- Delete the copies of the music files on your thumb drive.
- Then resync them with MB back to your thumb drive.
Hope that makes sense
Edit:
In fact, before you do any deleting mentioned above:
- get a new song into your MusicBee.
- ensure the embed artwork option is on.
- then sync that one new file to your thumb drive.
- if the artwork is embedded as desired, then the same process can be done for the rest of your files.
