Author Topic: Delete duplicates - anyone used an app for this successfully?  (Read 287 times)
greatfox
Hi, can anyone recommend an app that will delete duplicates based on same MP3 tags (artist and album and title)?
The problem is, I came from iTunes where I have two of each file in many folders, one starting with "1-", from when you told iTunes it was disc 1 and it changed the filename.  So, then I have two identical song files in the same folder, just one starts with "1-" and one doesn't.
Thanks for any recommendations!
  • Heal The World
I've never had to use it, but I'm sure MusicBee's Duplicate Manager is capable of handling such an operation.
Take a look and play around with it.
This would also have been discussed a number of times on the forum.
A thread like this may give pointers: https://getmusicbee.com/forum/index.php?topic=21957.0
Strength and Honour (2025)
