Author Topic: Hotkeys to select the n-th tab  (Read 888 times)
fiso64
In my web browser I can select a tab by its index by hitting Ctrl+Number. Since tabs are often static in a typical musicbee setup it would be great to have configurable hotkeys to quickly select the n-th tab.
for the next v3.6 update, i have added hotkey commands to select tabs 1..9
https://getmusicbee.com/patches/MusicBee36_Patched.zip
Last Edit: February 04, 2024, 07:28:45 AM by Steven
fiso64
Excellent, thanks!
