Author Topic: Add linebreaks after each group when showing headers in the same row as releases  (Read 853 times)
purplebee
Currently you can group albums to show them like this: https://i.imgur.com/ISk6JCE.png
My request is to add line breaks after each group (Release types, in my example), here's a mock-up: https://i.imgur.com/Rl0Vgtx.png
This could also be useful to make tier lists, like in this other mock-up: https://i.imgur.com/C8XC2qE.png
tjinc
It may be worth you taking a look at the option:
Albums panel header menu > Group By > Show Header In A Separate Row
purplebee
I'm aware of that option and use it frequently. However it's not exactly what I'm looking for, and it's not as space efficient either.
purplebee
A couple details to add to my original post:
*I'm making this request because I think it'd be easy to implement, since it's a small change and very similar to how headers are displayed when showing them in separate rows.
*This option could be added like this in the grouping menu:
Here's another mock-up I did with some light editing, to perhaps better illustrate my point:
Note: I'm not asking for the headers font or color to be editable, just to have a line break before each new header.
The Incredible Boom Boom
+1 this is a simple, but good idea
And I would. This would make the feature even cooler, but it would be a pain in the ass to implement.
+1 just in case
