Author Topic: artist view crash musicbee  (Read 513 times)
Yuin
iam not sure what''s happen. posting here to report.
https://filebin.net/yh2a31z0cfwgvos3
MusicBee v3.5.8778.33537P  (Win10.0), 26 Jan 2024 13:06:
   at #=zzaUg2jtYMoAL1pjAO4HFSEXJK6cb.#=z9rUjyp1UT9XA(#=z2mfqtOXLak2K5KoFsT1gvqc= #=zLc_v1fE=, #=zATrTd_jJniq7ZHJI4GCwtUAXYRP0[] #=z8dnSx_k=, #=zxRpfSVGVjiY49eIDukZ3CA4= #=zXboZE1k=, StringBuilder #=z5S3vmP8=)
   at #=zzaUg2jtYMoAL1pjAO4HFSEXJK6cb.#=z9rUjyp1UT9XA(#=z2mfqtOXLak2K5KoFsT1gvqc= #=zLc_v1fE=, #=zxRpfSVGVjiY49eIDukZ3CA4= #=zXboZE1k=)
   at #=z8ZA75$4NGPGWzztSUsplANufnqQL.#=zax9S6gNdPNfO09mt1w==.#=zUPO$_uTYO5icLVWOHw2a9uE=.#=zH6pWEW_HUXJL.#=zHOuyvACuG9lJ(Graphics #=zPwf3zgQ=, Point #=zgWtXYJA=, #=z2mfqtOXLak2K5KoFsT1gvqc= #=zLc_v1fE=)
   at #=z8ZA75$4NGPGWzztSUsplANufnqQL.#=zax9S6gNdPNfO09mt1w==.#=zUPO$_uTYO5icLVWOHw2a9uE=.#=zH6pWEW_HUXJL.#=zHOuyvACuG9lJ(Graphics #=zPwf3zgQ=, Point #=zgWtXYJA=, String #=z7jxx7g8=, String #=zb8$ThLfI0c8D, Boolean #=zU0gLwTe5fLLZxHpMGg==)
   at #=z8ZA75$4NGPGWzztSUsplANufnqQL.#=zax9S6gNdPNfO09mt1w==.#=zUPO$_uTYO5icLVWOHw2a9uE=.#=z_7k7Y4RG0jU$4NopSA==(Graphics #=zPwf3zgQ=, #=zFvNeozw= #=zuGX1IKT_Zlq9O8pXpg==, Point #=zgWtXYJA=, Boolean #=zU0gLwTe5fLLZxHpMGg==)
   at #=z8ZA75$4NGPGWzztSUsplANufnqQL.#=zax9S6gNdPNfO09mt1w==.#=zUPO$_uTYO5icLVWOHw2a9uE=.#=zhFw3hHrZ3QoHTpchDQ==(Graphics #=zPwf3zgQ=, #=zFvNeozw= #=zuGX1IKT_Zlq9O8pXpg==, Point #=zgWtXYJA=)
   at #=z8ZA75$4NGPGWzztSUsplANufnqQL.#=zax9S6gNdPNfO09mt1w==.#=zUPO$_uTYO5icLVWOHw2a9uE=.#=qwfhKalup4tbKI8ByUFyhvFPOjeElpY9UTkDddkjb5$4=._Lambda$__0(Graphics #=zPwf3zgQ=)
   at #=zSxogqLB5vHIPI2rExSQmIVU=.#=zp6llM431YMmX.#=zz$jAZSQ=(Graphics #=zPwf3zgQ=, #=zbQsMTTcIZcV8_$SYHQ== #=z4583pRz2a6vB, Rectangle #=z6MwxC_KtI3pm, Rectangle #=zsgmUJANfqMaM)
   at #=z8ZA75$4NGPGWzztSUsplANufnqQL.#=zax9S6gNdPNfO09mt1w==.#=zUPO$_uTYO5icLVWOHw2a9uE=.#=z21DE0KbRuW3M(Graphics #=zoxLgOw0=, Rectangle #=zlsey6P4EFCdd)
   at #=z8ZA75$4NGPGWzztSUsplANufnqQL.#=zax9S6gNdPNfO09mt1w==.#=zUPO$_uTYO5icLVWOHw2a9uE=.OnPaint(PaintEventArgs #=zqECjfPg=)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at #=zMaPzD13qqrKN7bfWCRzs5nU=.WndProc(Message& #=zppTazko=)
do you recall what you were doing when it happened?
if its repeatable can you send me a link to your settings file (help/ support/ view settings)
Yuin
here my setting:
https://filebin.net/sf9ujg03pyd74pmp
iam able to reproduce it.
from artist tab, change artists view to album covers then change it back to artists view.
thanks for sending your settings.
This should fix the issue
