Then the main list of playlists (all of the other lines in the playlist explorer column) are the auto-playlists that get generated from the playlists within that folder. These are the playlists that get synched to my mobile device.
I had no idea playlist folders were a thing. This changes quite a bit. Thank you!
I think it's fairly common that people create playlists in a certain order and expect the songs to be played in that order. I don't do that, but that's generally what play lists are. That's why your wish is kind of a no-go for me - it would complicate this functionality for the common use of the feature. If someone wanted to sort by album or something and forgot to restore the natural order, their playlist would be exported in the wrong (to them) order.
Of course, I wouldn't suggest to change something that could lead to suffering of those who have different setups
However, there's no contradiction here, there are two ways all could have their own with my suggestion applied:
1. They could sort by "natural order" - it would require remembering to do so, which I believe is still more straight-forward than having extra "sorting" auto-playlists.
2. This could be controlled by a setting "Export sorted by..." - which would default to "Natural order" but could be changed to "Displayed order" or something custom. This would be a solution to fit them all, and I think you'll agree that it's much easier and more straight-forward than the auto-playlist thing (which I'd never even think of without your advice - while a setting is simple and speaks for itself).
Rather than simply give a -1, I have given you two workarounds, one manual and one automatic.
True, and I really appreciate your advice. Folders I've already started to use; the auto playlist thing - I'll get to that as well, however I still think consider it a heavy workaround, so I'll keep hoping that the change discussed above could one day be implemented.
Thanks again for all your help!
EDIT: Oh my, "Playlist folders" even appear in "Include in playlist" sub-menu! What a sound advice, @frankz! My library just got way better and more useful thanks to you.
