Author Topic: <Album Complete?>  (Read 663 times)
MusicMee
I came across what I would describe as an <Album Complete?> edge case but worth reporting imo.
Let's say I have an album that is comprised of 2 discs and 20 tracks (10 tracks per disc). I have only ripped one disc and added it to MusicBee. MusicBee sees that I have all the tracks on the first disc (10 tracks) and is unaware of the tracktotal for any additional discs so it reports the album as complete. However - there is a whole disc missing (10 tracks missing). It seems to me MusicBee should check the disctotal when available and factor that into it's calculation.
Last Edit: January 14, 2024, 04:45:32 PM by MusicMee
tjinc
Are you sure about this?
From my testing, for an album with a missing disc, as long as the <Disc Count> field is set to the correct number of expected discs, then the <Album Complete?> field will report "?" (and not "Y"):
I can't claim to know the thinking behind this - maybe reporting that it is 'unsure whether the album is complete as there appears to be a disc missing'.
MusicMee
Thanks for calling this out! You are correct. I wasn't displaying the value of the tag but rather using it as a test condition and assumed it was a boolean (and treating it as such). The "?" makes perfect sense for my use case - there are times when there isn't enough data to reasonably conclude a disc is complete.
