Whenever i try dragging or moving a tab i get an error.
MusicBee v3.5.8447.35892P (Win10.0), 14 Jan 2024 14:53:
System.NotImplementedException: The method or operation is not implemented.
at #=zCJ5ZbFh4yYYfdpqpAoCXcqc=.#=zaiqk759IEiFJ.#=zr1T89qL9p$2O.#=zRLH1X$Y_b1iO(#=zIIcknEAGkkid& #=zacnWoKVUId26, IDataObject #=z7$tem6Y=)
at #=zCJ5ZbFh4yYYfdpqpAoCXcqc=.#=zaiqk759IEiFJ.SetData(String #=zbrGx4wg=, Object #=zz9d5$Yc=)
at #=zCJ5ZbFh4yYYfdpqpAoCXcqc=.#=zaiqk759IEiFJ..ctor(String #=zbrGx4wg=, Object #=zz9d5$Yc=)
at #=zXgkIGJhsHc2p5n0ascR8KvbQHcJg.#=zKu_$etLSijVi.#=zSa2whHMFmPGm(MouseEventArgs #=zIPqvHjQ=)
at #=zXgkIGJhsHc2p5n0ascR8KvbQHcJg.#=zSa2whHMFmPGm(MouseEventArgs #=zIPqvHjQ=)
at #=zqGcKt3ZASYF9$H9su9lVk78=.OnMouseMove(MouseEventArgs #=zIPqvHjQ=)
at #=zXgkIGJhsHc2p5n0ascR8KvbQHcJg.OnMouseMove(MouseEventArgs #=zIPqvHjQ=)
at System.Windows.Forms.Control.WmMouseMove(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at #=zqGcKt3ZASYF9$H9su9lVk78=.WndProc(Message& #=zMqlx0ro=)
at #=zXgkIGJhsHc2p5n0ascR8KvbQHcJg.WndProc(Message& #=zMqlx0ro=)
1/14/2024 2:34:26 PM - 10.0.19043.0 - 3.5.8447.35892P - System.NotImplementedException: The method or operation is not implemented.
1/14/2024 2:35:16 PM - 10.0.19043.0 - 3.5.8447.35892P - System.NotImplementedException: The method or operation is not implemented.
1/14/2024 2:36:18 PM - 10.0.19043.0 - 3.5.8447.35892P - System.NotImplementedException: The method or operation is not implemented.
1/14/2024 2:41:31 PM - MTP device detection failed=Retrieving the COM class factory for component with CLSID {0AF10CEC-2ECD-4B92-9581-34F6AE0637F3} failed due to the following error: 80040154 Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG).
1/14/2024 2:41:39 PM - 10.0.18363.0 - 3.5.8447.35892P - System.NotImplementedException: The method or operation is not implemented.
1/14/2024 2:41:41 PM - 10.0.18363.0 - 3.5.8447.35892P - System.NotImplementedException: The method or operation is not implemented.
1/14/2024 2:41:46 PM - 10.0.18363.0 - 3.5.8447.35892P - System.NotImplementedException: The method or operation is not implemented.
1/14/2024 2:41:51 PM - 10.0.18363.0 - 3.5.8447.35892P - System.NotImplementedException: The method or operation is not implemented.
1/14/2024 2:42:35 PM - MTP device detection failed=Retrieving the COM class factory for component with CLSID {0AF10CEC-2ECD-4B92-9581-34F6AE0637F3} failed due to the following error: 80040154 Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG).
1/14/2024 2:42:45 PM - 10.0.19043.0 - 3.5.8447.35892P - System.NotImplementedException: The method or operation is not implemented.
1/14/2024 2:47:01 PM - MTP device detection failed=Retrieving the COM class factory for component with CLSID {0AF10CEC-2ECD-4B92-9581-34F6AE0637F3} failed due to the following error: 80040154 Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG).
1/14/2024 2:47:10 PM - 10.0.19043.0 - 3.5.8447.35892P - System.NotImplementedException: The method or operation is not implemented.
1/14/2024 2:47:12 PM - 10.0.19043.0 - 3.5.8447.35892P - System.NotImplementedException: The method or operation is not implemented.
1/14/2024 2:48:12 PM - 10.0.19043.0 - 3.5.8447.35892P - System.NotImplementedException: The method or operation is not implemented.
1/14/2024 2:53:48 PM - 10.0.19043.0 - 3.5.8447.35892P - System.NotImplementedException: The method or operation is not implemented.
