Author Topic: This must be a bug: Custom views  (Read 697 times)
TheInvoker
It would make no sense if it's not a bug, since all other settings are OK
I'm trying to save different views for different playlists. The problem is between 2 playlists: one has Album covers, the other one is based on Artists
In the panel settings i see that both have the same settings even if they are different views but if i create custom views i can changes settings for one and not the the other one....GOOD
The problem is that there is one setting that, if changed for Custom View 1 (Album covers), changes also what i see in Custom view 2 (Artists)
And the settings is the positioning of the tracks (below, on the right,on the bottom etc)
I want them belows the album for album covers and on the right, for artits..but as i said this setting is shared between custom views and not remembered like all other settings i tried
You must be doing something wrong, it's working fine for me.
TheInvoker
i don't know, i did the same thing for other custom views/playlist and it always works (even if i don't understand i always have to set the view for a playlist because it resets every time i change something)
What i do is
1) Set the view i want (let's say artists)
2) open panel settings
3) change the settings i want (save)
4) save custom view settngs into the file
When i go back to the other playlist i still see album covers,  the custum view selected is correct, but the tracks are on the right
Maybe it can be caused indirectly by a third setting?
I save this
for "best of" custom view
but then ....
As you can see, other settings are differnt but track position is changed in both views if i change in 1 of them
I don't know.
You could create a post in the "Questions' board on this matter?
TheInvoker
After upgrading to 3.5, it seems that it's working for me too.
I'm curious ... what version were you using before?
TheInvoker
3.4 something...i don't know iof there is more than one starting with 3.4 but i know there were more numbers after the 4
Name of the installer is MusicBeeSetup_3_4_Update2
