The following is not really a bug at all, but rather a really minor issue that can still cause some confusion.When you save settings (Edit | Saved Settings | Save Settings Snapshot) the result snapshot file timestamp is in 12h instead of 24h. e.g.:
Settings 2023-Dec-30 1026.ini where it should be:
Settings 2023-Dec-30 2226.ini instead.
I attach a screenshot of such a snapshot file (File Explorer and taskbar clock) :
and one of windows Control Panel | Region, for reference:
Thank you
Using latest MB 3.5.8758 on win 11.
