Author Topic: Vinyl Sleeve  (Read 4649 times)
thinklater
Based on a Wallpaper Engine concept by Vairish and Fluent Carousel by mmakes.
https://github.com/tedhinklater/Vinyl-Sleeve/tree/main
Last Edit: December 28, 2023, 11:44:56 PM by thinklater
thinklater
Thanks, Hiccup :) Merry Christmas to you and yours!
Hopefully I can get BackgroundAlbumCover (the blurry album-coloured background) to layer underneath a transparent version of vinylbg.png so the surrounding colours are more dynamic, but at the mo, BackgroundAlbumCover seems to want to sit on top of the sleeve's layer. I tried setting vinylbg.png as an icon but no dice..
There is a value in 'Keep It Simple, Stupid"
But I can also understand the urge to use anything that may be available.
choices…
thinklater
Thanks man you prob saved me a few hours haha
rhubarbrhubarb
Hello, this looks great but the text is not centred for me. Installed the included fonts. Here's an imgur link.
https://imgur.com/a/9xo7hqx
Is there some MB setting I'm unaware of?
TY
thinklater
Hi rhubarbrhubarb, it looks like you're running the TM in the Now Playing window's embedded mode, make sure you extract the files to TheatreMode.List (not TheatreMode.Embedded) and run it from View > Theatre Mode > Vinyl Sleeve
gaiastar
Hi
Wow , I really love it
but should i install the fonts or just copy them?
amazing  , really love it
have you though for a second version with a spectrum ? could a nice mod
thank you so much
thinklater
TY
Hello from the far future (sorry), make sure you enable View > Theater Mode > Theater Panel Dock > Fullscreen
@thinklater...
I don't know how I overlooked this. Simple but wonderful. Thanks.
purplebee
TY
Thank you for this! I was having the same issue
Also would it be possible to have the orange center of  the vinyl change in color depending on the colors of the album cover?
Last Edit: April 27, 2025, 06:13:21 PM by purplebee
  • Heal The World
Depends, but most probably not. Off the top of my head:
- Is the vinyl background image a solid orange itself?
- If so, I'd then experiment with making that region transparent. Then overlaying the image on top of the BackgroundAlbumCover element.
Edit: but if memory serves well, the above-mentioned element has display priority over all other elements, meaning you cannot overlay anything on top of it.
Strength and Honour (2025)
purplebee
Thank you for the reply.
