Author Topic: Vinyl Crate  (Read 6073 times)
thinklater
Trying to replicate the feel of crate digging. Based on Fluent Carousel by mmakes and Album Tiles by Bee-liever
Fullscreen
Upcoming track titles active
Embedded in Now Playing tab
Embedded, with right sidebar
Lyrics active
Artist info active (and Shuffle turned off)
https://github.com/tedhinklater/SpotifyAMOLEDVinylCrateTM
Last Edit: December 24, 2023, 02:13:43 PM by thinklater
naresh
Hi Thinklater
I like this. But how do I show only album covers? Currently, the view shows all tracks instead of a single album cover.
Naresh.
BluMndy
  • He/They ~ Big Fan of Music ~ Bi ~ Autistic
does it work on Now Playing?
DJ KHALED!!!!
WE THE BEST MUSIC!!!!!!! :D  :D  :D
thinklater
Hi Thinklater
Naresh.
Hi Naresh I'm trying to understand, could you send a screenshot?
On the Now Playing Assistant? I'm not sure, I doubt it.
thinklater
Sorry Blu I've had my coffee now, it works on the Now Playing tab as an embedded TM, yep
naresh
https://imgur.com/xvUhN5X
Hi Thinklater
I am having trouble posting the picture. Hopefully the link works. If you can see the picture, you will see several pictures of the same album cover. Even though I cued three albums to play. I am thinking the several pictures are the tracks of the first album.
Your picture in this post shows different albums. I would like to see the same.
Naresh.
thinklater
Ah I see, the only way I can see that working is if track 1 is one album, track 2 is another album, etc. I shuffled the library which is why it shows different album covers. I'll try changing the parameters.
naresh
thinklater
Updated! Added Shuffle and Mute, Artist Info and Lyrics as well as a jump-to-track OnClick feature (just click the titles)
Last Edit: December 24, 2023, 02:14:48 PM by thinklater
thinklater
Hi Thinklater
Naresh.
Hi Naresh, there is a fix!
In Vinyl Crate.xml, where it says
<element name="#Cover_02" type="AlbumCover" id="Tracks[1]"
change
id="Tracks[1]"
to
id="Albums[1]"
and so on. Although, this means the upcoming song names will be positioned over the wrong album covers but the names can be disabled. Thanks to mmakes for the info.
naresh
Thanks, Thinklater and Mmakes, for that workaround. Works now.
How do I disable the song names? I don't really need them to show. I can see them in the playlist.
Naresh.
thinklater
Naresh.
It's the small button on the right-hand side of the upcoming vinyls, it might be tricky to see. It enables/disables the upcoming track names.
naresh
Hi Thinklater
Saw it and disabled the tracks. Now it is perfect for me. Thank you very much.
Naresh.
thinklater
Updated! Thanks to Naresh the skin now focuses on albums (not just the tracks) and has a playlist for selecting individual tracks. Best of both worlds!
Fullscreen
Playlist active (and album titles separately active)
Album titles active
Lyrics panel
Artist info panel
Embedded mode with right side panel
