How bad is the sound quality of those albums that you would need an individualized custom EQ for each file? Maybe you need better audio sources
EQ is generally used to compensate for deficiencies in playback equipment (headphones that have a frequency hump at an annoying level, for example), not to micromanage individual frequencies in each of 100,000 songs. There are professionals who do that for us when they mix and master the albums.
Useless request IMO. -1.
hi
they are all original cds so I guess high quality and flac files , there are different amps , some of them have higher frequencies , some with edge high frequencies and so on , and every user could find useful seeing different amps (different brands and models), different speakers (different brands and models), headphones (there are a lot of different brands and models)
musicbee is used a lot by hi-end users
thanks
Yes, that is exactly what EQ is for. You tune it to the output equipment, not to individual songs.
So you're now saying above that you
don't need individual EQ for each song, just each piece of equipment? That is entirely manageable using the preset structure already present in MB. Just have a different preset for each amp+speaker or amp+headphone combination. Problem solved.
Glad we could agree on this. It seemed before like you were talking about having an eq for each separate album. That's just overkill.
