Author Topic: Synchronize track playcount with last.fm  (Read 5468 times)
Kenika
Awesome! Just what I was looking for: I just migrated from iTunes to MusicBee and last.fm is killing all my play counts. So being able to tell that last.fm shall only update the play count when smaller is perfect. One question: can this plugin run alongside the built-in last.fm plugin or are there any issues coming along with both running at the same time? I assume that – at least – the play count update  option from the built-in plugin has to be disabled, right?
Thanks!
StoneImage
Thanks for making a great Plug-in! This Plug-in has been very helpful in enriching my listening experience.
Unfortunately, even though it syncs the play counts for most tracks, the play counts for some tracks are not synced correctly. For the cases where the synchronization failed, the log file recorded like following. In this case, the actual play count of this track appeared in last.fm  is "1"
2025/03/15 18:56:35 96 of 96: Zoltán Kocsis - Bartók: Mikrokosmos, Sz. 107 - Book 3: No. 96 Jolts
2025/03/15 18:56:35   TrackInfo Zoltán Kocsis - Bartók: Mikrokosmos, Sz. 107 - Book 3: No. 96 Jolts
2025/03/15 18:56:36   TrackInfo Zoltán Kocsis - Bartók: Mikrokosmos, Sz. 107 - Book 3: No. 96 Jolts | ERROR: MissingParameters
2025/03/15 18:56:36   0 -> 0  IGNORE
Is there any possible cause for this? Could someone give a hint to resolve the problem? FYI, the version of Plug-in I'm using is v1.2.2.
