Author Topic: Cannot bring up hidden task bar while in full screen mode  (Read 910 times)
Famas115
While MusicBee is in full screen and the task bar is set to "Automatically hide the task bar", placing the cursor at the bottom of the screen will not raise the task bar. I am running windows 11 with all the latest OS as of posting this.
Error shown here: https://imgur.com/a/Qccs8vW
i cant reproduce this except for one random time.
- which skin are you using
- do you have just one monitor
- and what is the DPI scale in the windows display settings
Famas115
Skin: Dark > Grey (Slim)
Monitor count: 1
DPI scale: Not too sure what that is but I'm at 1920x1080
Right-click on a blank area of your desktop > Display Settings > Scale and layout. What percentage is showing?
i still cant reproduce this with that skin and any dpi setting. So it will remain unsolved
LedHarvest
Same issue here. Win11 beta, running your patched version from https://getmusicbee.com/forum/index.php?topic=40726.msg221093#msg221093
So, with MB maximized:
1. moving cursor to bottom of screen does not raise the taskbar from autohide
2. pressing Windows key does raise the taskbar
3. Windows 'do not disturb' is switched on - https://imgur.com/3jirmH4
I'm running Windows scale at 125% with 2560x1440, MusicBee3 skin
