Author Topic: Visual Issue  (Read 1018 times)
Yuin
iam using Center-height alignment ~ (U+007E) tilde but somehow musicbee Mainpanel showing ˜ (U+02DC) Small Tilde.
bottom panel showing it correctly.
Source: https://wl.vern.cc/wiki/Tilde?lang=en#Variants_and_similars
Image File
https://filebin.net/qb9vyqzew8nzxy63
there also seems a little space before Della.
happen with all album on every tab.
Musicbee Setting
https://filebin.net/lkdnyt4u4mdnfziv
Musicbee Version
3.5.8730 P
MB does no manipulation of the font/characters displayed. The 2nd set of separators are bullet points generated by MB
Yuin
not the bullet point or space between bullet point but at the first of publisher name (Della) there is
seem a little "space" before D because its vertical is not very well line with R from relaxing & M from Makiko.
maybe zoom  a bit will help.
Relaxing
Makiko
 Della
similar to above example.
Red Arrow is showing tilde on main panel inccorectly.
Green arrow is showing tilde on bottom panel correct.
one is ˜ and another is ~ .
here another picture to make it clear about tilde position.
https://filebin.net/7r31ax6adn7bsv82
Last Edit: November 27, 2023, 10:50:52 AM by Yuin
The Incredible Boom Boom
Could this issue possibly be due to clashing between your Windows fonts themselves?
Have you tried searching based on for similar problems with other programs or within Windows itself?
Yuin
iam using Calibri font .
i think it only happen with musicbee because i spot it at first look.
i reupload pic file again due to expire
https://filebin.net/0vxib5l7povkr9n3
there is also new visual issue with crop circle artist with background enable
https://filebin.net/o6qe4vb89d6bxlen
karbock
In font Calibri, the regular tilde ~ is placed higher than in other fonts.
That explains why it almost looks like a small tilde in the upper part of your screenshot, although it is not.
But now: why is it different in the bottom panel? It's possible that another font (with similar metrics) has been selected for that location.
Could you check in Preferences -> tab 'Layout (1)' -> section 'bottom panel' if the check box in front of 'custom font' is ticked (and what font name is displayed)?
For your information, font 'Carlito' has almost the same metrics as Calibri, but the regular tilde is placed lower.
If you don't have it on your computer, it's free and available at Google Fonts:
https://fonts.google.com/specimen/Carlito
Below, a screenshot comparing Calibri and Carlito:
Yuin
you advice fixed tilde problem . thanks
@ steven crop to circle artist pictures issue
Last Edit: December 15, 2023, 09:54:58 PM by Yuin
Yuin
iam using dark W10 created by diego
https://getmusicbee.com/addons/skins/202/dark-w10-hidpi-supported/
also happen with chameleon dark by hiccup
https://getmusicbee.com/addons/skins/344/chameleon-dark/
i only try with these theme not sure about other theme
i cant reproduce any issues with either of those skins, so it will remain unsolved.
edit:
if you are using a custom background image, MB should block the 'crop to circle' setting but it would potentially cause the effect you see
Last Edit: December 17, 2023, 01:25:30 AM by Steven
Yuin
yes iam using custom background .
for daily usage i prefer using box artist pictures so i uncheck crop to circle setting .
thanks.
