I am trying to get player control buttons change depending on their toggle status, but it doesn't go well.
I've done this before using unicode characters (what is what I think other TM creators have been doing too), but I am now trying to use images instead of font characters. (for Playing/Paused status)
The result is that the image usually doesn't change, or sometimes it changes after a while, but it's unpredictable and not instantly following the actual playing status. (as e.g. the default player controls for TMs shows)
Perhaps I am doing something wrong though.
Here is a functioning TM xml that shows the behaviour:
<root>
<!-- button play/pause toggle -->
<element type="Icon" image="Images\toggle test\button_play.png"
xAnchor="Panel.Left" x="150"
yAnchor="Panel.Top" y="100"
mouseOverFg="255,255,255" onClick="PlayPause" visibleTrigger="NotPlaying"></element>
<element type="Icon" image="Images\toggle test\button_pause.png"
mouseOverFg="255,255,255" onClick="PlayPause" visibleTrigger="Playing"></element>
<!-- button stop -->
<element type="Icon" image="Images\toggle test\button_stop.png"
xAnchor="Panel.Left" x="50"
mouseOverFg="255,255,255" onClick="PlayStop" />
</root>
The image files for the player buttons can be downloaded
here and need to be placed in a folder named:
...\Plugins\TheaterMode.List\Images\toggle test
Perhaps someone can take a look?
