Hi karbock, thank you for the welcome. I will try some of the skins you suggest.
Hi Mayibongwe, I believe the skin I'm currently using is MidnightMETRO. I like dark skins because I tend to use the player at night to listen to ambient/drone streams. I just wish the scrolling info bit was bigger (but I'll try the suggested skins).
