Author Topic: Setting up my "Music Explorer" layout the same as my "Custom Search Results" one  (Read 768 times)
SBMark89
Greetings!
So, all the info is in the title. I'd like for the tracks of a selected album to appear in the right main panel, near the right pane where I keep my current playing list and lyrics, but anything I try doesn't seem to give me the results I'd like, instead of the album having the track list displayed below it, and one of the reasons for that is that would allow me to drag and drop multiple tracks at the same time even if I don't want to press shift.
Current version is 3.3.7491
I have three screenshots;  the first is of the music explorer, which is what I want to change. The second has the "album tracks" displayed like I'd want them, on the side panel, ready to drag and drop to the "now playing" tracklist.
The third screenshot is just a quick show of the panel layout settings.
Thank you so much about any tips on how to get this as I want!
The first step to take is to update to the latest version 3.5 of MB. Go to the first forum topic and install the latest version as your current version of almost two years old. Once 3.5 is installed come back here and download and install the latest patch update to 3.5. See my signature for instructions.
Note that if you're using the Windows Store version, you can update it from the first forum topic, but you will not be able to apply the patch update.
  • Heal The World
Links to the images OP posted that aren't showing up:
https://ibb.co/whRYPJS
https://ibb.co/fSkVR4N
https://ibb.co/DQx3MDN
@SBMark89
Unfortunately, the setting that does that does not appear to be supported in the Music Explorer tab.
You can try requesting it in the wishlist board if it's that important to you.
This is the setting in question.
Strength and Honour (2025)
