Author Topic: Buttons on Bottom Panel not Working Properly  (Read 1286 times)
forjunkemails
Hi everyone
I've been getting this weird problem lately while using musicbee. For whatever reason, the region that the buttons on the bottom panel are working in is not the exact region where the buttons are. The regions that they work in are shown in the red boxes in the image. I believe it started with some plugin but I disabled all of the plugins and other themes do not work either. Is anyone else experience anything similar and/or has a solution for this?
Thanks
Last Edit: October 23, 2023, 05:53:19 AM by forjunkemails
can you send a link to your settings file (help/ support/ view settings)
Thanks for sharing your settings, however i cant reproduce any issues nor can i think of any reasons why that would happen. So it will remain unsolved
The Incredible Boom Boom
Which version of MusicBee are you using?
You might find it worth the time to install a portable instance and re-import your settings to see if the problem persists.
