Author Topic: How to add a screenshot to a post  (Read 58493 times)
cartman005
To add an image to a post:
1. Create the image by taking a screenshot with the PrtScn button and paste the image into an application such as Paint. Save the image. Alternatively, you can use another application such as Windows Snip to create the image.
2. Crop the image to show what you want to display and possibly add markings to highlight certain areas. You can use Paint for this.
3. Upload the image to an image hosting site such as MediaFire or ImageShack. These are both free image hosting sites.
4. Get the direct link to the image and copy it. This link cannot be a page which has the image on it, but must be the actual address of the page. It should end in .jpg, .bmp, or .png if it is the address of the image, such as http://www.example.com/screenshot.jpg.
5. In the post that you want to add the image to, you can simply paste the link and post it. Example:
http://upload.wikimedia.org/wikipedia/en/b/bd/Windows_7.png
(Advanced) To make the image actually appear in the post.
6. Surround the direct link with the tags
[img] [/img]
to make the actual image appear. It should look like:
[img]http://www.example.com/screenshot.jpg[/img]
Example:
7. You can make the image link somewhere by adding the
[url=http://www.example.com/link]
tags. So the full link would look like
[url=http://www.example.com/link][img]http://www.example.com/screenshot.jpg[/img][/url]
Example:
8. Now, you can center your image by adding the
[center] [/center]
tags around the link.
Example:
9. Finally, you can resize the image so it doesn't take up the whole page by adding 'width=' or 'height=' in the img tag, so it would look like
[center][url=http://www.example.com/link][img width=200]http://www.example.com/screenshot.jpg[/img][/url][/center]
Example:
So, as you can see, it can get complicated. But of course, the final steps are not entirely necessary.
For additional tags, please see this page. I am not sure if they are all implemented here.
Last Edit: July 23, 2011, 12:43:42 AM by cartman005
beeing good
Might be worth mentioning that you need to paste somewhere after pressing print screen as nothing really seems happens when you press it, it doesn't 'create the image' as point one suggests.
Good tutorial aside from that.
cartman005, I think 'share' option of MediaFire should be mentioned. Its not very obvious that MediaFire can provide direct links to images.
greenday1987
  • Long live OiNK!
http://imgur.com/ is my preferred choice of image host. This is a good guide and I'd never used some of the tags such as width/hight settings which is handy :)
RIP OiNK
ma_t14
+1 for imgur.com
I hate the way imageshack has gone with the "domain unregistered" bullshit (btw does anyone know how to solve this  ???)
If you are on windows there is a great tool for Imgur called Imgur Uploader. It automates the whole upload process by adding an option to the "Send To" menu. If you wish it can also add the appropriate bb code for you and you have different options for thumbnails, full size etc
Extremely useful tool when uploading screenshots here or other forums
Last Edit: August 05, 2011, 10:40:55 PM by ma_t14
greenday1987
  • Long live OiNK!
Other forums 'wink'
Movie trackers and such?
RIP OiNK
ma_t14
Other forums 'wink'
You may be biased, seeing that you have a what.cd account  :P, but no that's not what I meant
Alexis
Very informative post.  I certainly did not know I had these options for my posted images. THANKS!
desplantes
There is just a problem :
When you want to send a link without the http// thing but like that :
MusicBee, nobody knows (except if you put your mouse on it)
that's an hyper text.
Let's try :
MusicBee
So we can define that blue colour in texts are hyper texts.
Cheers.
jistme
