OK, this really is a problem...
Bonus Question! I just imported my library from iTunes. The first few playlists I spot-checked were 100 percent groovy.
Then I found a whole bunch that are just "exclamation points". Some of good playlists and bad playlists even point to the same songs!
I can't spot any particular distinction between the good and the bad... (i.e., even two playlists in the same iTunes subfolder, one's good, one's not).
Thoughts?
Thanks! (Screenshot attached
