Author Topic: Keeping Folders Organized (New User Question 3/3)  (Read 2021 times)
NPZwar
…But is that even possible?…
Welcome to the forum NPZwar.
Yes, that can be achieved.
For restricting the length of the title you can use the $Left function.
For not showing disc numbers for albums that are not multi-discs albums, I would assume these albums would not have the disc# tag populated at all to begin with. (what would be the use?)
And if that tag is empty, it will obviously also not be used for renaming.
Thank you, that's is very helpful. No, all albums have the disc# tag populated, the use is simply consistency throughout. So even if its a single album, it says "disc 1 of 1".
…all albums have the disc# tag populated, the use is simply consistency throughout. So even if its a single album, it says "disc 1 of 1".
I would call that wrong and unneeded, not consistent ;-)
Consistent (in my opinion) would be to only have disc numbers for albums that are actually multi-disc releases.
For single non-album tracks in my library, I also don't tag them with 'track# 1'. That would not make sense.
Last Edit: March 29, 2024, 01:49:24 PM by hiccup
NPZwar
Just on this point...you do not have to let musicbee reorganize your old files in order to have it organize any future files.
As long as you keep the setting in the green box off, it will not touch your old files (provided they're not in a folder set to monitor in the blue box).
To automatically organize your future files, you'd set your "holding" or "intake" folders (where you put new rips and downloads) in the blue box and then turn on the setting in the red box.
But you don't even have to do that.  I don't.  You can manually choose what to organize and when yourself by keeping the blue box empty and the setting in the red box off.
Oh, thanks. That's very helpful as well. MusicBee has plenty of options to dig through, obviously many more than íTunes.
All my music files are in a folder called music, and there are a two different subfolders: There is the directory "ALAC", which is for all stereo music files (and all these files are ALAC), FLAC (which are all multi channel music files, just a few hundred). (Note: The reason multi-channel and stereo files are separated into FLAC and ALAC file types and directories is just for legacy reasons, I know either format could do both.... I just kept it like that, so the file type automatically tells me if it's a stereo or multi-channel file.)
So I would set up the MusicBee library to the "ALAC" directory, but in your setup, it would only sweep and organize new files (when they are added to ALAC), but leave the old ones as are? That's great and already helps a lot.
Short question: if I ever edit one of the old files in MusicBee, say, change the album or track titles, will it then also change the actual directory and file name? (I would assume so, as that's what I hope it would do).
Anyway, thank you very much for such quick and expert replies. Great forum!
If you turn on the setting in the green box giving MB full automatic control of your organization, then yes.  Your library will be auto-organized according to the template used as soon as you turn this on (which sounded like something you didn't want initially but maybe I'm wrong).  Then, going forward, any changes you make to tags that are referenced in your template will result in file name / location changes.
NPZwar
Maybe I just explained it way too complicated, I try to make it simple an clear what would ideally work for me, though you have already helped me quite a bit.
Ideally, I could setup my MusicBee library to the folder "ALAC", where it would not overwrite all the files at once, but should I then add files or make changes to old files, it should indeed change the file name and location as well. If that's not possible (which may well not be, because I obviously want two things that may be at odds with the options available), I will try to work around it somehow.
I would not even mind if all the files were managed by MusicBee, I am just worried about the countless hours it would take to rename 90,000 files in three different locations. :-)
NPZwar
I know that lots of people tag their music according to various parameters, and that's all fine. :-)
I have all the disc number set, and overall I have found that missing tags are more problematic than redundant tags (if they are consistent and correct). So I can quickly see if a track belongs to a single album or is a multi-disc album. I don't think I have any tracks that don't belong to an album.... If I did, the single track would be an album to itself. :-)
Last Edit: March 29, 2024, 02:31:45 PM by NPZwar
If you are not willing or able to remove disc# from single-disc albums, you could use this virtual tag in your renaming template to only output a disc number for multi-disc albums:
$If($Max(<Disc#>,<Album>)>1,<Disc#>,)
This is not possible.
The part for future files entirely possible as I described here.
You'd just want to have a separate "intake" folder  where you put incoming files that's not located within your existing structure.  MB will look at this folder and organize anything it finds, moving it into your existing folder structure without touching the files that are already there.
So if you have...
C:\Music\ALAC
C:\Music\FLAC
Just add...
C:\Music\Incoming
...or something similar, reference that in the blue box, turn on the setting and set your template in the red box, and then put all of your new files in C:\Music\Incoming.  If your template says to sweep files to C:\Music\ALAC\<WhateverTag1>\<WhateverTag2>, then the new files will get organized from C:\Music\Incoming into the existing structure named in the way your template say to.
Just as an aside, why is it important where your files are located and what they're named.  Isn't the point of tagging and using a library manager to avoid needing a perfect folder and naming structure to get library information?
Last Edit: March 29, 2024, 02:22:26 PM by frankz
Absolutely true.
But you spoke of being consistent in also showing the disc number if there is only one disc.
And yet, for this naming template you don't want to show the disc number for single-disc albums...  ;-)
Personally, when I see 'disc#1' in my library, it tells me there are more discs.
If there aren't, I don't want to see 'disc #1'.
NPZwar
Absolutely true.
Indeed, quite right. That is simply because iTunes is inconsistent, and I guess I am trying to "import" some of that inconsistency to MusicBee. I would be happy and fine if ALL tracks would start with "1-01" instead of "01" even when it's a single disc album, it's just that iTunes doesn't do that. And I just want to keep the number of files MusicBee edits when taking over to the necessary minimum.
Ah, before I forget, one more reason I have this consistency: Almost always files that get ripped or added to the collection need to be re-tagged, so there is consistency throughout.
If the disc number is "1 of 1", it means, there is one disc. Period. If the field is empty, it can mean there is just one disc, but it could also mean that the tags of a multi disc album are missing. That happens sometimes, that people tag an album "Album Title Disc 1", "Album Title Disc 2" and don't insert any disc numbers... so when I then change the album title to "Album Title", the tracks mix and mingle where they shouldn't. So when ripping a CD, I habitually insert the disc numbers, no matter how many there are.
Last Edit: March 29, 2024, 05:15:17 PM by NPZwar
True that.
While I can imagine it being some OCD fun to get folder structures 'right', it will never be 'right'. Too many variables involved.
And MusicBee won't care about it.
Time spend on that will probably be spent much better on perfecting the metadata of your music.
I think a lot of times people let "perfect" be the enemy of "good" when it comes to this stuff.
If it was me, I'd let my current folder and naming structure stand untouched for simplicity and let MB manage my future files loosely into that structure in the most easy to manage way possible.
I also don't auto-sweep new files or any of that, so maybe I'm an outlier.
NPZwar
That could be one reason to use a library manager, but it's not the only one and is not mine.
There are several reasons why I keep the folder structure as diligently as I do. The main reason is that the library exists in multiple locations, and it is much easier to check and keep backups consistent if the folder structure is consistent as well. I don't have any music files directly on my PC, they are all on an external hard drive. All the music is in the directory "music", which basically has two subdirectories "ALAC" and "FLAC", and within these two folders, everything is grouped according to "Album Artist" "Album" "Tracks". There are no other files in the directories, no image files or log or text files. That means, when an album is renamed  in the library manager, the folder is also renamed. That has several advantages:
1. It makes it easy to control and keep all backups consistent. I can just right-click the ALAC folder on my disc and the ALAC folder on my NAS and see the exact same number of bytes and the exact same number of files, so I know the backup is perfect. This has already helped me several times over the years to notice if a backup for some reason was inconsistent or did not get all the files.
2. Any copy of the music directory is a perfect copy and can replace any other existing copy. A few years ago, the "core" hard drive with my music collection crashed on our stone floor. Fortunately, I could just buy a new hard drive, copy all the files over from a backup, and everything was 100% as it was before.
3. I periodically check the files with PerfectTunes for accuracy, so that's easy as well if they are all in one folder.
4. The files on the NAS are accessed from a variety of programs. A hifi streamer, a few players on my smartphone, file managers, etc. A clear directory structure is very useful for navigation there. On the NAS are not JUST music files, but the music files are all in one folder with subdirectories, and all music playing devices are referred to that one folder.
Last but not least, when I started to rip my CD collection and buying high-res files, I started organizing them as well. So my files were "orderly" from the beginning. It was then the logical step to put them all into the same folder. I never had a loose collection of files spread out over different directories that I started to manage one day with a library manager. My collection was "consistent" from the very beginning, and so I just have a natural inclination to keep it that way. I admit, I enjoy that the files on all hard drives/NAS exist in the exact same spot. Makes many things easy. Relative playlists can be used on any drive from any program. I often use file managers so consistency helps there. All my computer files  are more or less in orderly directory structures.
In any case, frankz and hiccup, your insightful responses have certainly helped me get a better grip on MusicBee and how to proceed. Very much appreciated.
Last Edit: March 29, 2024, 03:26:19 PM by NPZwar
