Author Topic: Manage duplicates is seeing asx files as duplicates  (Read 376 times)
MUSICWASP
Just starting to use Musicbee and most things seem to make sense so far except this.
So if I import an entire discography of an artist I no doubt get duplicates...  then I use Manage Duplicates to delete the duplicates and replace them with asx files so each release appears 'complete'.
Then next time I scan the library using Manage Duplicates it sees all my asx files as duplicates to the file each asx is pointing to.
Is there a way for the Manage Duplicates scan to ignore asx files? I had a look around in the preferences (which there are a lot of) and nothing jumped out at me.
Would appreciate any help you can offer.
Cheers!
welcome to the forum musicwasp
This needs the file extension being added as a condition.
How to do that is currently a bit hidden and not easily available:
     • create a virtual tag
       label: Extension
       formula: <.Ext>
     • add that tag as a condition in the fitered files option in the Duplicates Manager:
       Selected tags > More > Extension
There exists an open wish to make this a bit easier and less hidden b.t.w.:
https://getmusicbee.com/forum/index.php?topic=39616.msg214236#msg214236
+1-ing it might help getting this suggestion implemented.
Last Edit: September 07, 2023, 08:18:46 PM by hiccup
tjinc
Hiccup just beat me to it - I went with:
A workaround would be to create an auto playlist with the criteria .Ext - is not - asx and run the duplicates manager on that playlist.
Hiccup just beat me to it - I went with: …
The more good suggestions for alternative ways to reach a goal the better!
