Author Topic: SSX.dll problem.  (Read 1338 times)
aktor
If i try to open files in windows explorer the following error appears. Musicbee.exe bad image windows\ssx.dll is not designed to run in windows or it contains an error. I re-installed musicbee but it didn't help. Any ideas?
where have you downloaded mb? i don't think mb uses ssx.dll.
aktor
Here and copied last patch over it.(i didn't uninstall) Did also run  ccleaner for registry. didn't help.
What types of files are you trying to open in Windows that causes the error to appear?
Are you using the Windows Store version of MB?
ssx.dll is certainly not part of the MB installation. It may be from a plugin. In which case you should disable all plugins, exit and restart MB. Then add the plugins back in one a time until the error appears. Then you'll know which plugin is the cause. Then post a report on the plugin's thread so the plugin developer can take a look at it.
You could (should) also search through the entire MB directory and sub-directories to see if ssx.dll appears.
aktor
The command that triggers error is "locate in windows explorer". I run sfc and It found this errors. Must be a windows problem. Any idea how to fix.
2023-08-20 20:00:21, Info                  CSI    0000019f [SR] Cannot repair member file [l:22{11}]"sppcext.dll" of Microsoft-Windows-Security-SPP-ClientExt, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2023-08-20 20:00:21, Info                  CSI    000001a1 [SR] Cannot repair member file [l:22{11}]"sppcext.dll" of Microsoft-Windows-Security-SPP-ClientExt, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2023-08-20 20:00:21, Info                  CSI    000001a2 [SR] This component was referenced by [l:202{101}]"Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.WindowsFoundationDelivery"
2023-08-20 20:00:21, Info                  CSI    000001a5 [SR] Could not reproject corrupted file [ml:520{260},l:46{23}]"\??\C:\Windows\System32"\[l:22{11}]"sppcext.dll"; source file in store is also corrupted
2023-08-20 20:00:22, Info                  CSI    000001a8 [SR] Verify complete
2023-08-20 20:00:22, Info                  CSI    000001a9 [SR] Verifying 100 (0x0000000000000064) components
2023-08-20 20:00:22, Info                  CSI    000001aa [SR] Beginning Verify and Repair transaction
2023-08-20 20:00:23, Info                  CSI    000001ac [SR] Cannot repair member file [l:26{13}]"sppcomapi.dll" of Microsoft-Windows-Security-SPP-UX, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2023-08-20 20:00:24, Info                  CSI    000001ae [SR] Cannot repair member file [l:20{10}]"sppwmi.dll" of Microsoft-Windows-Security-SPP-WMI, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2023-08-20 20:00:45, Info                  CSI    000001b0 [SR] Cannot repair member file [l:26{13}]"sppcomapi.dll" of Microsoft-Windows-Security-SPP-UX, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2023-08-20 20:00:45, Info                  CSI    000001b1 [SR] This component was referenced by [l:202{101}]"Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.WindowsFoundationDelivery"
2023-08-20 20:00:45, Info                  CSI    000001b4 [SR] Could not reproject corrupted file [ml:520{260},l:46{23}]"\??\C:\Windows\System32"\[l:26{13}]"sppcomapi.dll"; source file in store is also corrupted
2023-08-20 20:00:45, Info                  CSI    000001b6 [SR] Cannot repair member file [l:20{10}]"sppwmi.dll" of Microsoft-Windows-Security-SPP-WMI, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2023-08-20 20:00:45, Info                  CSI    000001b7 [SR] This component was referenced by [l:202{101}]"Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.WindowsFoundationDelivery"
2023-08-20 20:00:45, Info                  CSI    000001ba [SR] Could not reproject corrupted file [ml:520{260},l:46{23}]"\??\C:\Windows\System32"\[l:20{10}]"sppwmi.dll"; source file in store is also corrupted
2023-08-20 20:00:46, Info                  CSI    000001bd [SR] Verify complete
this question belongs on a windows forum
open admin command line and execute:
Dism /Online /Cleanup-Image /RestoreHealth
then:
sfc /scannow
aktor
i got error 87 for Dism /Online /Cleanup-Image /RestoreHealth. I have windows 7.  Should I manually replace files?
